Hey guys what do you suggest for an oil filter for a 450-500 wheel horsepower 2019 Accord. Those are just power estimates until my build is complete.
Mods:
Intake
Bigger turbo
Flex fuel kit
Downpipe 200 cell cat
Full 3 inch exhaust
Direct port methanol injection
Oil catch can
600hp rated black intercooler
Hard aluminum intercooler piping
540 rat enhanced: 5w30 Quaker State Full synthetic oil
Mobil 1 Synthetic multi vehicle formula (10 speed automatic transmission)
I narrowed it down to Wix Xp, Purolator boss, Fram racing HP 17. The by pass valve on the Wix is 8-11 psi the fram is listed at 16-28 psi. The Purolator boss is 14-18 psi. The problem with the HP 17 Fram is while it flows a lot more gpm the filtration rate efficiency is 95% compared to 99.x% on the other two filters, but I guess the stock oil pump wouldn’t even be able to crank that much out in the little 4 banger. Which filter would you guys suggest ? There is a Motorcraft fl816 that fits physically but it’s almost an inch shorter and I’d be losing a lot of filtration media with that one and they discontinued the exact one, the fl822, that fit my car.
Thanks !
I'm on several 10th gen Accord forums, and this sounds to me like another perfectly good car is about to be butchered and someone is going to spend a lot of money to ruin a car and end up losing even more when they decide they actually don't like it, then try to sell it to someone else who won't even pay stock-car prices for it. This is the result of getting advice from "bros" who post how awesome their car is while quietly selling the car at a massive loss after a couple years.
Just know that if you go through with all those mods, you are essentially committing to owning the car until it's totaled, or selling it for an even greater loss. Your insurance company won't give you a cent for all those mods. And very, very few buyers are going to want to massive question mark of buying someone else's hot rod.
I'm a Honda guy, but I'm also an engineer who makes a living in engine development, specializing in fuel system development. I submit to you that 450-500hp in a front wheel drive car is very unwise. Your STOCK car cannot put down the stock power levels until about 30mph, and that's only with traction control intervening to help it out. Instead of having a car that rips just off idle, you'll have a laggy car that doesn't pull until 3000rpm, and that's why an MHI. If you make the mistake of going as big as, say, a PRL P700, you'll have an ocean of regret that you traded 5000rpm of useful rev range for a tiny sliver of barely more power at high rpm.
If you want to upgrade your car without butchering it, just settle for a tune and a stock FL5 CTR turbo. This will run 350hp easy on pump gas, keeps the the torque at level less likely to grenade your trans, and keeps good response for daily driving. You don't need an intercooler upgrade. Many racing teams have gone from huge intercooler back to the stock one because a huge intercooler adds a ton of lag. On top of a big turbo, it's even laggier.
You don't need exhaust upgrades. You don't need an aftermarket intake. Definitely do not go to a typical K&N style filter. The filtration is awful. YOu definitely don't want hard pipes that have higher assembly and dynamic stresses and lead to cracked components. You every wonder why Honda put flex sections there when hard pipes would be cheaper for them?
The MHI stage 2 is absolutely the biggest turbo you should ever consider for a K20C that sees any street duty whatsoever, with the FL5 turbo eating its lunch in the real world.
Hondata has videos showing the aftermarket intercoolers adding lag and a whopping 5hp only at peak. Skip them.
It's your car, do as you please. But remember this post and come back to it after two years of driving a laggy car with a glitching transmission and a problematic flex fuel system after you've done the headgasket a time or two. Don't say you weren't warned.
I think you might benefit from doing a bit more homework-- and more importantly, doing your "research" at places other than the 10th Gen accord forums and youtube videos that start with "Yo, what up, it's your boy.."
