Oil filter micron ratings.
This may be a dumb question.
But is it safe to run 99% at 20 micron filters? Or is there too much flow restriction?
Iv been running the factory PF63 filter on my 6.2 Denali. But now im learning that anything over 20 microns can cause engine wear. And the PF63 is a 98% at 30 micron filter.
Iv been running the factory PF63 filter on my 6.2 Denali. But now I'm learning that anything over 20 microns can cause engine wear. And the PF63 is a 98% at 30 micron filter.
I've been running them for years with zero issues.
Not for a newer member, but for someone who has been on this Board for 10 or 20 years, that may be different!
The Oil Filter restriction thing is a myth since some oil filters have a bypass in the oil filter and it might be in the engine block!
We do have an Oil Filter Expert on this board who knows everything about Oil Filters and this Micron stuff, he may chime in soon!
Whats yalls opinion on the carquest premium’s?
Looks like they are premiumgard filters listed at 99% at 20.
We have an account with AAP through work so i can get them cheap and easily.
CQP are excellent filters.
What about the NAPA gold filter? Its a PG But shows 30 micron? Is that just an outdated spec from when they were wix?
You'll have no issues, been running Donaldson oil filters on & off which at 99%@15 Microns.
Please link to who and where to get one. They have a whole handful of filters, what is the automotive version name/color? Also maybe the part# you use and for what car or truck , so we can use that info to track down one for our cars.
Flow over efficiency is a myth. Plenty of high efficiency oil filters flow just fine, and your engine won't know the difference in any minor flow difference supplied by the positive displacement oil pump. A few PSI difference in dP vs flow isn't going to matter unless in the are you're racing the engine at near redline most of the time and the flow coming out of the pump is over 10 GPM. Not many vehicles put out that much flow to start with.
As already mentioned, it's actually the particles 20u and less. Particles larger than 20u can however get chewed up by moving components and get broken down into smaller particles that could do damage. A high efficiency oil filter will capture more particles below 20u than a less efficient filter. A higher efficiency filter will also retain its efficiency better as it loads up with debris, because oil filters actually lose efficiency as they load up. That's one thing someone can glean out of the ISO 4548-12 efficiency rating. High efficiency oil filters can't have a high ISO efficiency if they shed a lot of already captured debris like a low efficiency filter does.
So many myths about oil filters. Almost as many about the oil itself.
Two of the worst offenders with synthetic media, absolutely. Built to withstand a bomb, but like a screen door that will barely stop mosquitoes…
Many people use the Toyota filters and they have worse filtering efficiency yet they go 200-300k miles. 40 microns is still smaller than most bearing clearances.
Baldwin oil filters have been 12 micron since way before it was cool.
It's hard being a 12 micron oil filter in a world dominated by 40+ micron oil filters.
In those days 12 micron normal was a decent diesel fuel filter.
