Oil Filter Mesh and Flow
Concord, North Carolina, USA
Is it possible that a wire or plastic mesh in an oil filter affects either the flow rate or the total media available for filtration? I am thinking in particular about the PurolatorBoss that has an integrated polymer mesh. Does that not take away media space?
No. The concern you raise is a fallacy and a non-issue.
The polymer mesh is used to support the filter media and assist in the media maintaining its shape. Synthetic filter media does not have enough internal stiffness to maintain its shape on its own while in service. So manufacturers use a stiff backing matrix to hold the filter media in place. It prevents wavy pleats over the life of the filter.
Other manufacturers accomplish the same thing with a wire backing. Neither approach (polymer or wire) is superior to the other, rather just different approaches to solving the same problem.
Thank you.
Thanks.
