Oil drain plug?
Alabama
My 96 Regal uses a metric drain plug with a built in o-ring seal instead of a copper or nylon washer.
Does GM make a similar drain plug with built in o-ring for my 75 Chevy truck with the ½ x 20 threads per inch drain plug?
You can check dorman's site dormanproducts.com for your truck but its the same plug used up to 96 on most GM cars and trucks dorman motormite 090-052. See also cgenterprises.com
I assume you can get one at any GM dealer. The only issue is whether it's oversized by now
Thanks m2200b for the links it looks like no one makes a 1/2x20 drain plug with a built in o-rong.
Looks like I will try the rubber metal washer #2603.
