Oil compsition which to choose
western australia
Oils compositions from MSDS data sheets.
Which one of these formulations is the more shear stable and likely to have a decent Noack value compared to the others listed.
Climate
0 degC winter to 41 degC summer.
70% City driving and 30% Fwy driving.
OCI 6mths or 10000km.
The vehicle can use any of these oils due to design and OEM recommedation.
Or is this a silly question not enough data.
5w60
INGREDIENTS CAS NUMBER PROPORTION % W/W
1. Mixture of 1-Decene, tetramer, mixed with 1-decene trimer, hydrogenated
& 1-Decene, homopolymer, hydrogenated 68649-12-7/68037-01-4 30% - 60%
2. 1-Propene, polymer with ethene 9010-79-1 < 10%
3. Complex mixture of additives Mixture 30% - 60%
15w50
2. 1-Propene, polymer with ethene 9010-79-1 10% - < 30%
3. Complex mixture of additives Mixture 10% - < 30%
10w40
& 1-Decene, homopolymer, hydrogenated 68649-12-7/68037-01-4 > 60%
I would guess the 10/40, as the bigger the difference between cold and hot ratings the more likely the base stock is to break down. A difference of more than 40 (Eg 0/40 or 10/50) is regarded as the boundary between normal and semi race oils that need a more frequent OCI. Trucks use 15w40 and some cars with long OCI's use 5w30 or even 0/20 because they are in effect long life oils and very shear stable.
For most normal use cars the winter viscosity rating is very important in wear terms, so don't pick a 15w40 instead of a 5w40 without good reason.
