Oil bath brake additive for gear lube?
Gulf of Alaska
I am working on Geenie GTH1056 telehandler forklift with Spicer 213 axles. I just overhauled one of the axles. It has wet brakes that are lubed by the diff oil. The Spicer/Dana axle manual calls for SAE 80W90, GL4, MIL 1205, with "additives for oil-bath brakes".
My oil distributor (Chevron) is telling me to use limited-slip gear oil, & the Geenie dealer is telling me to just use posi additive from the auto parts store. The axle holds six gallons of oil, so like six tubes of posi additive?? I have never seen a rear diff in a truck that holds more than 5 quarts. Neither of these sounds correct to me & the last thing I want is for the brakes to squeal or be grabby.
What say you?
A wet brake is basically the same mechanism as the clutches in a posi or the wet clutch in a motorcycle or a tractor. It's a friction material creating friction against a steel disc. If they're telling you to use LS additive or an LS fluid then that's what I'd use.
