Quote:
According to Polaris, "Elemental Analysis by ICP (inductively-coupled plasma) detects up to 24 metals...not greater than 10µm in size."
It more complicated than that. Much more. I also don't believe the 10µm upper limit. Most ICP spray chambers have a cut-off of 5µm. Droplets larger than this overload the plasma.
This is from a paper on analyzing slurries by ICP-OES and is essentially what you have when analyzing oil containing particles using a solution to standardize as oil analysis does:
Quote:
To achieve close to 100% recovery using solution standardization, a consistent particle size of 3 microns or less is generally necessary. Goodall, et al. wisely included the density of the particle into the determination such that the higher the density the smaller the particle size needed to be.
The density comes into play because in a spray chamber the particle size is aerodynamic diameter, which in simplest terms is the particle size times the square root of the density.
Assuming a 5µm aerodynamic diameter upper limit, the maximum particle size seen for lead would be 1.5µm and 3.0µm for aluminum.
The 10µm quoted by Polaris might be for some efficiency
Ed
