OG Fram Titanium FS3593a C&P
BrendanC
$100 site donor 2024
Houston, TX
2003 Honda Accord 2.4L K24 196k miles
in service: 5k miles
off: Fram Titanium FS3593a
on: same
Oil cooler pad started leaking, didn’t torque the adapter nut tight enough when i installed it. Filter looks great! this K24 now that it’s cleaned out (2x BG EPR flushes, 1 run with HPL Engine Cleaner 30/Valvoline Restore and Protect) runs extreemly clean and burns zero oil.
Date code 90th day of 2020 ... before the leaf spring stamping machine went bonkers. Still has holes in the center tube, but no leaf spring end cap gasket.
on: same
Oil cooler pad started leaking, didn’t torque the adapter nut tight enough when i installed it. Filter looks great! this K24 now that it’s cleaned out (2x BG EPR flushes, 1 run with HPL Engine Cleaner 30/VRP) runs extreemly clean and burns zero oil.
Great work. Filter did its job well. Thank You
