Off the shelf oil with highest ZDDP ?
CA USA
I had been using VR1 10w30 oil in my flat tappet engines for years. It was over $5 a quart. I was happy to find Quakerstate Defy 10W30 had high enough levels of ZDDP to protect the cams in older engine for a lot less money than the VR1. The they changed the formula for Defy. So I switched to Rotella 10W30. Now it seems they have changed the formula of that and reduced the level of ZDDP. I can't find what the new level is, Does anyone know the amount of ZDDP in Rotella 10w30 T4, T5 and T6 ? I've also read that Valvoline reduced the ZDDP in VR1 is this true does anyone know the amount of ZDDP in VR1 10w30 ? I'm having a hard time finding this information and want to used the a off the shelf oil with the most ZDDP that I can find. Thank you.
Originally Posted By: Donald
Amsoil
This is the 3rd time this week you've been caught not reading the entire post.
Amsoil
What did you expect? Off the shelf means different things to different people
Zddp plusmax, one little bottle to any gf5 or sn oil and the add pack won't be upset by it.
Does anyone know the amount of ZDDP in these oils. I was thinking about using a additive. Without knowing the amount off ZDDP I don't want to end up with too much. I've read that can be as bad as not enough.
One of the stoutest oils out there, Mobil 1 0w-40, has 20% more ZDDP than the typical Xw30 SN limit. If you need more, add just 1/4 cup of https://rislone.com/product/3x-concentrated-engine-oil-supplement-with-zinc-treatment/ to boost it even further to about 40% more than a standard Xw30 SN oil (1200 ppm total).
Is that still true with the current formulation?
Rotella still has around 1200ppm, one of the Shell reps told me this not too long ago that the CK4 formulation was still this way.
Mobil 1 Turbo Diesel Truck 5w40
Good for gas engines too, more ZDDP than the Mobil 1 0w40
I have a ton of this stuff and plan to use it with Mobil 1 Advanced Fuel Economy 0w20 to reduce the amount of ZDDP for less risk of cats going bad.
Where do you buy Mobil 1? It's not on the shelves around here.
Yes. All current Mobil 1 phosphorus (the limited part of ZDDP) is at:
https://mobiloil.com/~/media/amer/us/pvl/files/pdfs/mobil-1-oil-product-specs-guide.pdf
Thank you everyone. I think on my next oil change I will go with Pennzoil conventional and the Rislone Zinc additive. I think cost wise it's a good way the go and that way I will know my engines have a good amount of ZDDP. I won't have to worry about formula changes in the oils that they don't tell you about.
Excessive ZDDP will prematurely wear your engine.
