Would like to draw on the collective wisdom here.
Daily driver is a 99 Taurus, 3.0L Vulcan, 99K miles. Currently running Mobil 1 5w30 on 5K mile change intervals with Motocraft FL400S filter.
Engine uses about 1/2 qt per OCI. Usually when the level drops to the ADD line, its time to change.
What I would like to do is at 5K miles, change the filter and top off the oil. With the new filter and the oil use, I figure I would be adding about a quart.
Until I get a sample pump, to do a used oil analysis, how long should I run after the filter change? Another 3K miles? More? Less?
Thanks
CC3
Thanks
CC3
