And then there's the snafu with some of the heavy duty (F250+ and even Excursions) being OBDI for emissions even though they're wrapped in the '99+ SuperDuty body style. Only 3 minutes and worth a watch:
OBDII was mandatory for all (or almost all) cars for 1996. However, the ‘94 and ‘95 Mustang V6 had the OBDII port, albeit in beta form. The Mustang V8 didn’t get OBDII until 1996. Just an FYI.There are some vehicles that had partial OBD2 capabilities in 94-95, especially for the California market but they were still technically OBD1 as they did not have full OBD2 functionality. An example would be the 95
And the 1964.5 Mustang had a generator not alternator. Something about Mustangs.OBDII was mandatory for all (or almost all) cars for 1996. However, the ‘94 and ‘95 Mustang V6 had the OBDII port, albeit in beta form. The Mustang V8 didn’t get OBDII until 1996. Just an FYI.
We had a 95 Camaro about 8 years ago. Thing was a pain. Couldn't read it via either OBD protocol. Thankfully the only code it ever threw was...idk, but at emissions time we just reset the comp via battery disconnect and went straight to the emissions place. They couldn't scan it, either. No light, no problem, and it passed the sniff test. Lol. Keep that in mind, guys. 94, buy. 96, buy. 95, stay away if emissions is an issue for you.OBD2 PCMs were mandated by the federal government in the US for all 1996 light duty vehicles. There are some vehicles that had partial OBD2 capabilities in 94-95, especially for the California market but they were still technically OBD1 as they did not have full OBD2 functionality. An example would be the 95 Corvette and F-body cars. They had OBD2 ports, PCMs with FLASH memory and the capability to be reprogrammed from the port, and most of the emission standards for OBD2 programmed into them, but still used all the OBD1 protocols for GM otherwise.
I couldn't tell you if any Ford vehicles had something similar as I'm not that familiar with their OBD1 systems as I've never owned any of their 95 and earlier vehicles. Maybe there are some Ford guys on here with some computer tuning experience that might have more info.
Never had any issues with my 95 K1500 I sold to my ex and a 95 Suburban I owned for a while. Both worked fine via OBD1 and even have a good amount of live data if you have the right scanner. So not all 95s are bad.We had a 95 Camaro about 8 years ago. Thing was a pain. Couldn't read it via either OBD protocol. Thankfully the only code it ever threw was...idk, but at emissions time we just reset the comp via battery disconnect and went straight to the emissions place. They couldn't scan it, either. No light, no problem, and it passed the sniff test. Lol. Keep that in mind, guys. 94, buy. 96, buy. 95, stay away if emissions is an issue for you.
Same on my 97 and 98 F350 and F-Super Duty1996 F250 good old OBD1, and no airbags.
My bad, I was specifically referring to the F-body cars. They were OBD1.5, and from what I've read, even dealers just threw parts at them because they were difficult to talk to if not impossible.Never had any issues with my 95 K1500 I sold to my ex and a 95 Suburban I owned for a while. Both worked fine via OBD1 and even have a good amount of live data if you have the right scanner. So not all 95s are bad.
But yes, the 95 trucks were still pure OBD1.
The only thing you need to read a 95 Corvette or Fbody PCM is a OBD2 style connector and an OBD1 compatible reader. Or just use a jumper connector and directly connect to the pins on the OBD2 port. I've scanned and data logged many 95 Y and F bodies over the years and never had any issues.We had a 95 Camaro about 8 years ago. Thing was a pain. Couldn't read it via either OBD protocol. Thankfully the only code it ever threw was...idk, but at emissions time we just reset the comp via battery disconnect and went straight to the emissions place. They couldn't scan it, either. No light, no problem, and it passed the sniff test. Lol. Keep that in mind, guys. 94, buy. 96, buy. 95, stay away if emissions is an issue for you.
Correct! Only thing I will add is the 94 Corvette started it for the Y body and I call it OBD1.5 lol - I have a 94 Corvette I have owned since new.OBD2 PCMs were mandated by the federal government in the US for all 1996 light duty vehicles. There are some vehicles that had partial OBD2 capabilities in 94-95, especially for the California market but they were still technically OBD1 as they did not have full OBD2 functionality. An example would be the 95 Corvette and F-body cars. They had OBD2 ports, PCMs with FLASH memory and the capability to be reprogrammed from the port, and most of the emission standards for OBD2 programmed into them, but still used all the OBD1 protocols for GM otherwise.
I had heard some 94 Corvettes had the OBD2 port but I've never personally seen one. My 94 Camaro still has the OBD1 port but the PCM is the FLASH memory one that can be programmed from the port, it was used in all the 94-95 LT1 engines. 94-97 turned out some weird stuff in the transition from OBD1 to OBD2, you really have to pay attention to what you have in these years, there are so many special exceptions.Correct! Only thing I will add is the 94 Corvette started it for the Y body and I call it OBD1.5 lol - I have a 94 Corvette I have owned since new.
