The Autel MD806 Pro is great high end DIY scanner that gives you a lot of added features like SRS relearn, ABS codes, DPF, etc that cheaper scanners won't have. It can't do some things that professional shop grade scanners can do like bi-directional control, ECU programming, etc so if you are running a shop it would be somewhat lacking as a primary scan tool.
