Since we've got a new house, I've wanted to add solar panels for auxiliary lighting, landscape lighting, and for charging things like cell phones, laptop, etc. (if the power goes out)... I have a generator for the big stuff, this is just something to play with and so I don't need to run the generator "all the time"...so I'm not looking at something large to power the house, or to tie into the grid.
I need some input...I'm looking at Northern Tools, they have Sharp 80-Watt panels (they have good reviews), a 30-Amp controller, and the AGM batteries (staying with an all 12-volt system). I'm considering (as a entry level, to start) two panels (160 watts total), the controller, and a 200 Amp-Hr battery. It would cost about $1400 to the door, which I don't consider too bad.
Does this sound like a good start? I would be able to add at least two if not three more panels before I exceed the capacity of the controller. I guess I just can't wrap my head around the draw versus the charge rate...two panels should produce around 10 amps (assuming 160 watts * 90% efficiency = 144 watts /13 volts = ~11 amps). A 10 amp battery charger will charge pretty much any battery (even fully discharged ones) overnight in my experience...and a 200 amp-hr battery should run a lot of LED lighting overnight??
For the smaller systems, what's everyone finding works?
