so i got a manual transmission fluid replaced at a local shop. i got the fluid, but the washer that i go did not fit, and so the mechanic just had to use the old washer for the drain plug and no washer for the fill plug. this is the factory washer, and it had one transmission fluid change before this.
is this okay?
i am just worried that it will leak or something, and i cant get under the car so is there any way to check if it has leaked?
the car drives fine, and the shifting feels smooth.
should i get another manual transmission oil change and make sure a new washer is there?
also, is there any way to tell manual transmission fluid is low?
is this okay?
