noisy little civic
My 05 civic engine is noisy. Ive adjusted valves nothing is wrong. I guess its just the solid valvetrain a few honda guys say there car makes the same noise and it gets louder as the engine warms up. So my question is what oil could I use to reduce noise. I dont mind going thicker. It Is running 5w20 but I hate the thought of oil that thin. What should I use? Thanks guys its non vtec as well.
Hmmm my Civic has the same non-vtec engine, and someone actually commented how quiet it idles a couple weeks ago. Castrol GTX is a little thicker, you could try that 5w-20 flavor.
what was the valve lash on the intake and ex b4 and after? 2 mil too loose and this type engine will be noisy. Is this an SOHC VETC design with VTEC on the intake only? Or one that activate /deactivate 1 intake valve per cyl setup at X rpm ? I run Quaker State Ultimate Durability 0w20 with the 57356 wix with 1/2 qt RT5 10w30 hdeo for a add "booster" No Single of-the-shelf oil has been quieter than some lucky blends we tried** This is the lucky strike blend for 2013
** have not tried maxlife. Im not an NaXx adds package guy, I suppose ...
It idles very quiet it's noisy around 2500 rpm I think the exhaust was .10 an intake was.08 iirc.
It's non vtec.
Originally Posted By: walk23
asking an oil to correct a design flaw
+1. Best answer that can be given.
Considering these engines last forever I doubt it's a design flaw more like a difference in design. Solid valvetrains are louder than hydraulic . But are better in every other way. So it's hardly a design flaw. I just think 5w20 is a stupid choice in an engine with solid valvetrain. That's just my own opinion.
I've never found the oil's viscosity to make much difference to engine noise that due to a mechanical issue.
That said, try any cheap 5w30 at your next OCI to satisfy your curiosity as to whether makes a noticeable difference.
D17A1 is a great engine that kind of loud.
Some have said in the past oil with lots of boron made their engine quieter. Don't know how true that is.
Why are you taking your Civic on a road course?
I missed something !
Also what oils have boron in them ill give it a try. Why are these engines loud? I've heard they are but why?
easiest to find high Boron content oil is Quaker State in the green bottle. I believe the Quaker State Ultimate Durability has a shot of Boron as well, just not as much as the green bottle
PP and Purlator Synthetic filter has quieted down our V. Next change I may try Mobil 1 High Mileage 5w20 with the same filter. It's interesting the V hast lost two mpg since going with the current combo.
Any oil produced by Conoco-Phillips will have a high boron content. If you can find the Trop-Arctic 5W-20, it's usually the best priced and it's also a syn blend.
Kendall GT is another one from C-P with high boron, and it also has titanium which I've noticed in some recent thread comments might also help quiet valvetrain noise.
The best available choice would likely be the Motorcraft 5W-20 from WalMart. Always in stock and cheap in the 5 quarts jugs.
All three are relatively cheap and easy to try for a short OCI.
I don't know why, but Shell oils like Pennzoil, Quaker State have been the quietest in every engine I've used. Mobil 1 has been the noisiest.
My engines have remained very quite for 35 years using Mobil 1 oils.
All generations of Honda 4 cylinders (D, B, F, H, K, L, R) have always done two things consistently IME:
-clackety valvetrain, even w/clearances set to spec
-piston slap
ALWAYS.
Luckily, neither of these things will stop them from performing or accumulating high miles. They're just aesthetic issues to me. If you want to try and quell the noise, why not try oils with different HTHS values to chart out a possible correlation.
