Hi guys,
Car is a 2001 Mitsubishi Mirage.
Stock clutch master cylinder.
The transmission is a mix of about 3 transmissions put together so unsure what clutch slave is on it.
What happened:
I took off the clutch master and clutch slave (I am prepping the car to get it onto a circuit so checking over a few things).
I cleaned both master and slave with brake clean (not sure if this is a bad idea?
I installed everything back and tried to bleed the system however pressing the clutch does nothing - There is no resistance and the fluid doesn't go down.
I eventually used a little siphon type pump to get fluid though the bleed nipple on the slave so there is fluid in the line (not sure whether there is also lots of air though) but the clutch pedal still has no resistance.
My thoughts are either the clutch master has completely failed but unsure how since it was working before removing it or that there? Could it be the brake cleaner and/or going dry? It sat without fluid for a couple of months.
Or I am unable to bleed it properly - But as mentioned I siphoned some fluid into the line so by now depressing the pedal should allow me to bleed it?
What can I do to test what is wrong?
What happened:
