Cut open a Nissan OE filter used on my '92 Maxima with the VG30 motor. Yes, it's used - I just can't bring myself to cut open a perfectly good unused filter.
Observations:
-a fair amount of oil was still in the filter so I'm thinking this indicates a good ADBV (silicone?), especially considering my filter is mounted with the open end down.
-what's with the string on the filter media? I think purolator uses these, yet the filter can says 'made in Japan' on the outside.
-metal endcaps
-small inlet holes
-a good number of holes on the metal inside part of the filter
-without actually measuring, it looks like there's a fair amount of filter media. The pleats are fairly deep too.
-thick canister (there has to be an easier way than using a hacksaw)
Questions:
-can someone tell me what the metal thing in the 4th picture is? I don't think it's a bypass valve, as my car has one mounted on engine filter mount. Is it just to hold the filter assembly in place? If it is a bypass valve, how does it work?
-the Mopar filter is what I'm using on my car now in place of the Nissan OE. I hope it's built as well (it was much cheaper to buy). I notice it has bigger inlet holes than the Nissan, but the gasket doesn't look as well made as the Nissan gasket (the last two pictures are comparing gaskets). The Nissan gasket is flat with a raised rounded ridge all around it, whereas the Mopar is just a big old flat gasket. It has an orange coloured ADBV too, so I hope it's the same material as the Nissan.
Oil filter
How the heck do you post pictures to BITOG?
[ May 06, 2004, 12:18 AM: Message edited by: rcy ]
Observations:
-metal endcaps
-small inlet holes
Questions:
Oil filter
