Originally Posted By: Zack1978
Hi everyone,
I want to do a trans service on my 1996 Nissan Maxima. I am not doing a complete flush as there is no need, so I will only be replacing 4 or 5 quarts of ATF. What would the best option be for a fluid? I don't think I can justify the high cost of Amsoil for this car, so what are some other good options? I don't want to run Wal Mart ATF.
Thanks,
Zack
Use the Nissan Matic D. I know Its a very old ATF and if you use the wrong ATF that has to much ZINC can cause problems... read below, that is from NISSAN Site. I just hate to read horror stories or a person trying to save 10$ and using SuperTech ATF or even a good After market ATF and it ends up causing problems. I myslef have wanted to use Valvoline Max Life in my Honda but stopped myself. I 1 time used Castrol Full Syn Transmax that says on bottle for Honda and I got lucky.. However I will never do that again... Read this below and perhaps this will help you.
Here is some info I found about Matic D
Matic D
Matic D is the oldest of the Nissan AT fluids. Nissans
Matic D is an ashless petroleum-based ATF
with
low zinc content. The ash in other fluids may
cause a change in friction response.
Zinc may adhere
to the clutch linings and cause slippage and damage. In
a pinch, Dexron III can be used. However, Dexron III is
a GM specification and trademark, and while it is the
most similar to Nissan Matic D, it is not necessarily the
same. Matic D is competitively priced and it’s always
the safest bet for Nissan cars requiring Matic D
Also I know people who specialize in Imports, I know several techs who work at a Repair Garage called THE J.A.P SHOP..... J.A.P Stands for Japanese Automotive Professionals and they have told me they trust Beck/Arnley for FLUIDS and Parts 100%. Here are the specs to the NISSAN MATIC D via Beck/Arnley and they should be the same as Dealer Nissan Matic D however I cant find the specs online.. However I wouldnt be surprised if they were the exact same. Also the zinc thing would really bother me if I were you, I know some ATF use Zinc to help combat wear
Appearance Red Clear
Flash Point oC (oF) 200 (392)
Pour Point oC (oF)
-50 (-58)
Viscosity at 40oC 34.5 cSt
Viscosity at 100oC 7.3 cSt
Viscosity Index 182
Dynamic Viscosity at -40oC 30.69
Density at 15oC 0.85
to:
Make Reference Number
Nissan 999MP-AA100P (Matic D),
Also Beck/Arnley is the only 1 the is OE approved for use in Honda and Acura and like I said I know Techs that swear by Beck/Arnley. You can find good deals on it on Amazon or Ebay. Also there parts are perfect, If you look on YouTube a guy compares factory parts to Beck/Arnley parts then compares them to HIGH QUALITY after market parts and you can see a difference.
Also check this out the pics below.
