There usually isn't any adjustment screws on modern equipment and they tend to come a bit on the lean side for emissions. The problem with that is the least bit of junk or varnish clogging the carb puts it over the top. To enrich, I would first clean the carb. If that didn't work and I had eliminated everything else drilling out the jet a tiny amount.
I would check the valve lash fist, myself. Also, a partly plugged fuel filter can cause lean running, too.
