New tool thread
I picked up a new Icon G2 14" 3/8 locking flex head ratchet. It was a bit dry but the screws are in with a lot of loctite, I used a small soldering iron tip on the screws only and they came right out. The ratchet has low back drag and it is smooth, the locking mechanism is much nicer than a push button.
While there I got a 12v angle cutoff tool, I used it yesterday and it cut 10mm bolts with no trouble at all, get a 12v 4A battery for this tool, it is bit of a dog with a 2A. The cost with a 4A was $94, a bare tool 20v Dewalt is $200, sure the dewalt has more power but for small stuff this one is possibly one of the more powerful with a 4A. It has a depth of cut accessory, has 3/8 or 7/16, 5 yr walk in warranty and 3 yr on the battery.
View attachment 281821View attachment 281822View attachment 281823
View attachment 281824View attachment 281826
I love my M12 cutoff for small fasteners under the vehicle. U-bolts, exhaust clamps, random bolts.
I wanted a stubby 1-1/16" ratcheting, but couldn't find one (I understand why), so I ordered a cheap Husky and fired up the bright blue light machine. View attachment 283182
Tagging @AutoMechanic because this stuff makes him lose sleep, but I'm helping you through exposure therapy. Confront your fears, young man! :eek:
If it was mine it’d be in the trashcan after the job lol. No modified tools on my box.
Oddball M11x1.25 tap & die. Dodge caliper slider pins used this. Hard to find so I wanted a set on-hand, but just cheap ebay specials View attachment 283181
Might as well grab an M9x1.25 with some M9 helicoils used on many VW and a few Dodge models. I have had a few that were stripped out by some ham fisted buffoon and found it in my lap. The threads are in the knuckle with no separate caliper bracket.
Modified tools are some of my treasure, I would not get rid of any of them.
The only tool that would bleed an old 60's MG clutch. Vacuum, pressure, gravity would not get it 100%, that bugger was made in Hades by the devil himself. This tool did it in a few min.
I misspoke, too, as I called it a vacuum bleeder but it's a reverse bleeder. I is smart.
In my recent -- and still ongoing-- 14b drum brake adventures I found myself once again wishing for a drum puller that could handle 13" drums. I have the Astro but it does not have that much spread.
I stumbled upon the Lang 833 which claimed a capacity of 13" dia and 6" reach. The slide-on 14b SF drums are ~6.5" deep but I figured worth a shot. It didn't hurt that there was one in Warehouse Deals for $56, while retail is about $125. It arrived in a generic cardboard box but miraculously everything was there. There's presently another showing in Warehouse Deals for $71:
https://www.amazon.com/dp/B007QV85IK
True to specs, it couldn't quite reach:
You lose about an inch to the rotating head of the forcing screw, so I decided to add 2.75" to the arms (@AutoMechanic trigger warning)
Proof of concept, I now have a puller that can actually accommodate 13" drums, at least on a SF axle:
I understand this may not help you rust belt guys much as the arms and the forcing screw are kinda light duty. Still, the concept is to preload (and install a lugnut, just in case!) and then produce vibration through the means of your choosing.
When I first pulled these drums, I had to preload a slate bar with my hip while giving her the ol' reach-around with an air hammer on the WMS. As I get older, such gymnastics become more challenging.
Finally, OTC offers a HD puller as the #6979 that would likely work out of the box, but it comes with a heavy duty retail of ~$370. I'll keep my eyes peeled for a deal.
@D60 i always appreciate and learn something from your posts, for that, I thank you!
Seeing as I am on a journey to learn, hence buy and driving beaters. I have begun my adventure into drum brakes. After a teardown, inspection, cleaning and reassembly of the Sunfire wheel cylinders, I needed some more tools to prepare for the possibility I will have to replace them.
To get them out, I will likely need to remove the wheel bearing to gain better access. For that I needed a T50 bit. Do I have one? Probably. Where? It might be in my tool kit in my 6 horse trailer. Could I go look? No. I found a set of torx on a 3/8 drive on sale. As well, the wheel cylinder bolts need an E8 torx socket. That I dont have. Also got that on sale. Found at our local Cambodian Tire.
Also found a cheap tire changing kit there, on sale. Got a torque wrenching, breaker bar and a few sockets. These will work on the trailers and companion vehicles we take to horse shows. This keeps me from assembling and disassembling a tool kit every trip we make.
You lose about an inch to the rotating head of the forcing screw, so I decided to add 2.75" to the arms (@AutoMechanic trigger warning)View attachment 283198
Proof of concept, I now have a puller that can actually accommodate 13" drums, at least on a SF axle:View attachment 283199
The adjuster should have backed off enough to let the drum come off unless that was the problem. I wish my suburban had that little rust on it. If it was a Midwest vehicle you beat it with a sledge till the lip falls off then there is no problem getting the drums off.
