I did this exact change on an older subaru legacy and can tell you my experience.
Originally Posted By: Audi Junkie
Just put the two tires next to each other and you will see the 205/60 is much beefier. That is a common upgrade that works great. Forget about the mpg theory junk, there will be no difference. More traction and better ride over potholes is WELL worth it. The tires will even wear longer. Trust me.
There are a lot of choices in that size. My fav is Goodyear Eagle GT.
I lost roughly 1 mpg. In fact, I've done this on 3 cars and lost a small mpg on all of them, even factoring the minor differences in diameter. On my 2002 accord, it was closer to 2 mpg.
A narrow tire tends to track straight easier, provided it's a quality tire, in my experience. A wider tire is more stable, handles better, corners better, looks better. A narrow tire is less apt to hydroplane.
The width of the rim is important. measure your rim width. make sure it's not too narrow for the 205. tire rack will have the specs for that size tire on the "specs" tab.
If the tire size results in a more rounded case profile, the ride will not be as harsh. If the sidewall ends up looking flat, you'll feel bumps more.
the 205/60 would be a good fit (check rim width). I think the 60 series is a great comprimise between comfort and handling.
M
