F1A94 10 rib dedicated is gonna replace the F1c 8 rib different cam and parts too numerous to mention(last week)![]()
nice C6, I am assuming your username implies a certain air ingestion device of the belt variety?![]()
I don't see what the problem is in the pictures. On the black ball mount you can reverse the slider to lower the front of the trailer coupler.
Sure there’s always a way but not with the expensive weigh safe hitch that will help at today’s speeds.Im not a experienced car hauler and I have a lot of it coming up as soon as my vette is finished.I don't see what the problem is in the pictures. On the black ball mount you can reverse the slider to lower the front of the trailer coupler.
I know it’s gonna be a call to weigh safe$$No way to install a weight distributing hitch on that trailer? You would only need it when hauling cars, not when making a dump run.
Exactly I needed a vote for the 3/4 springs.It will be easier the second time.Those springs are way beyond the payload of the truck which is probably no more than 1,500 pounds. A mistake at best. Now instead of blindness you will be hunting ground squirrels.
Personally, I would ditch the weigh-safe hitch anyways, not because it doesn't work, but because I'd rather have the WD/Anti-sway hitch. (If you're going to be toting the car around a lot and longer distances.)Sure there’s always a way but not with the expensive weigh safe hitch that will help at today’s speeds.Im not a experienced car hauler and I have a lot of it coming up as soon as my vette is finished.
The WD hitch will not be able to put enough weight on the rear axle with those springs-to properly adjust the front. He has messed with the dynamics of the truck-big time.No way to install a weight distributing hitch on that trailer? You would only need it when hauling cars, not when making a dump run.
Unless you're talking ancient half tons with 15" wheels, you can easily swap the rubber for Load Range E. And regearing isn't that big of a deal or expense in the grand scheme.Looks like a 2500 or 3500 pickup would be better-I HATED towing heavy with a 1/2 ton, too high gearing, and P-metric rubber!
No different than putting a big set of airbags on the truck.The WD hitch will not be able to put enough weight on the rear axle with those springs-to properly adjust the front. He has messed with the dynamics of the truck-big time.
The springs are the problem......What's the trailer weigh? 1500 pounds? And the Vette. 3500? 5000 pounds total. 500 pounds tongue weight. I don't see any problems.
The WD doesn't care what the rear spring rate is, the weight will shift regardless.
The springs have nothing to do with the amount of weight pushing down on the truck.No it won't. Those springs will not compress enough to put the proper amount of weight in the rear axle.
I'm sorry-I have extensive towing experience-I'm not debating this with you. The front of the truck will not be within 2 inches.The springs have nothing to do with the amount of weight pushing down on the truck.
Gravity, yes, springs no.
He could have no springs on the rear and the amount of weight the trailer is putting on the rear tires would be the same as if there were iron bars in there.
The factory original springs in the truck would have been fine. If he added stronger springs, they could technically carry even more.The springs are the problem......
HUH?No it won't. Those springs will not compress enough to put the proper amount of weight in the rear axle.
