New Mobil 1 Racing 0W30 VOA
I wouldn't. Not necessary and not formulated for a modern engine. ZDP levels this high can be bad for aluminum components and emission system.
I have a Race Header with no CAT so i'm not too worried about it. The aluminum engine on the other hand is a concern...
I'd run anything in the Si if it has extra anti-wear additives. Haha.
Overkill and probably mis-application for you Artem. These oils are more about enduring severe apps and protecting an engine for 'short' lived life expectancy. That's my take, anyway. How many race cars are built to last 20 years and continued to be driven with minimal HP/slight compression loss etc?
I guess you're right Jim, as much as i'd love to see all zeros on my used oil analysis.... I'll pass on the race oil.
VOA in text format
Code:
Elements PPM
ALUMINUM 0
CHROMIUM 0
IRON 2
COPPER 0
LEAD 2
TIN 2
MOLYBDENUM 1654
NICKEL 0
MANGANESE 0
SILVER 0
TITANIUM 0
POTASSIUM 6
BORON 118
SILICON 14
SODIUM 8
CALCIUM 3152
MAGNESIUM 8
PHOSPHORUS 2202
ZINC 2442
BARIUM 0
cSt Viscosity @ 100°C 62.9
SUS Viscosity @ 210°F 11.03
Flashpoint in °F 415
Fuel % -
Antifreeze % -
Water % 0.0
Insolubles % 0.0
TBN 9.9
TAN
ISO Code
You could use that oil as an additive to your street oil.
One quart of that mixed with 5 quarts of regular oil would give you 276ppm moly and boost your zinc about 400ppm
Yes. I am running 2.5 qts Mobil 1 Advanced Fuel Economy 0w30, 24 oz Mobil 1R 0w30, and 8oz Lubeguard BioTech in my Hyundai.
^I'd love to see a used oil analysis on that.
Yeah, me too!
Ok guys. I'll send in for a used oil analysis.
Only have 1700mi on this fill, so
please be patient. Should be about
the first of June, or so.
Using this stuff on a street car is like you eating carb gels all day because "athletes eat them, so it must be good, right." No you'll just get fat.
Originally Posted By: Garak
Mobil claims 1850 ppm here. That's still too high for normal street use, but that's not the intention of this product.
Yap, 1850 Zn and 1750 P. I can believe these numbers all right.
The link is a great resource, BTW.
This part is interesting:
Quote:
0W-30
Advanced full synthetic formula
specifically designed to maximize
horsepower under race
conditions.
0W-50
engine protection under race
conditions.
I always believed Mo in engine oil is to decrease friction (in boundary conditions) and not to decrease wear.
I just wish they'd cover the conventional line for us. The HDEO line is fairly well documented already on their sheets, though.
As for friction versus wear for Mo, isn't it considered an anti-wear additive anyhow?
Originally Posted By: Jax_RX8
This oil has enough additives in it, it could be used as an additive - run Mobil 1 Advanced Fuel Economy 0w30 oil change and substitute one quart of this in your oil change to pull up the Moly and ZDDP.
Exactly.... that is what I am doing... 1 qt. 0w30 racing oil as a supplement in my 7 qt. pan. I have a 393 stroker @ 500HP and I want the xxxtra protection.
You also get the benefits of the AFE's detergent pack with this mix, if it is a street car.
