Buster thanks for posting.
The 0W-20 is now heavier with a HTHS of 2.7cP and a slightly higher VI of 173. Also the MRV has improved to 9,200cP.
The 5w30 is much the same with a slightly higher 172 VI.
The 0w30 has changed the most, reverting back closer to the spec's prior to the last up-date of 09/10.
Overall it's lighter with a HTHS of 3.0cP and a lower MRV of 13,250cP down from 17,100cP.
The big hit is to it's VI which has dropped from 180 to 166 but that's closer to what it was prior to 09/10 at 169.
On balance at temp's above freezing I see no advantage to the 0w30 over their 5w30, certainly not in cold start performance and therefore I'd prefer the 5w30 for it's slightly higher HTHS vis.
