New Mobil 1 15W50 formulation.
Mobil 1 15W-50 is being reintroduced based on popular demand. Mobil 1 15W-50 provides higher viscosity, designed to provide extra protection for performance vehicles and vehicles that operate in severe service, such as towing, hauling and racing. Additionally, Mobil 1 15W-50 contains higher levels of anti-wear (ZDDP or Zinc DialkylDithioPhosphate) that may be required for certain racing applications and camshaft designs. This is a new Mobil 1 15W-50 formulation and is not the same as the product that was marketed a few years ago.
I copied and pasted this off Mobil`s website. What exactly is *(ZDDP or Zinc DialkylDithioPhosphate)* ?
This is the oil I`ve been running since it came out. Just curious what the ZDDP is,that`s all. This oil make my car`s VG30DE run absolutely silent!
ZDDP is a family of zinc salts of dithio organophosphates. They are soluble in nonpolar solvents, so they easily dissolve in mineral and synthetic oils used as lubricants...The main use of ZDDP is in anti-wear additives to lubricants (eg. greases, motor oils, hydraulic fluids). To date it is the dominant anti-wear agent, present in most machine and motor oils in amount of about 1%. However for motor oil applications the amount of ZDDP has to be minimized, as the zinc and phosphorus emissions damage catalytic converters. ZDDP also has anticorrosive and antioxidant properties. ZDDP is usually manufactured with dialkyldithiophosphates as intermediates, by a reaction of phosphorus pentasulfide with suitable alcohols. These intermediates are then neutralized by adding zinc oxide, yielding ZDDP.
I got the above information from Wikipedia.org.
Here's more info pasted from their website-- sounds like they're bringing back the high-ZDDP formula. But the cap is clear or silver, not red, so maybe it's not the same formulation as the red top was. I'll be a happy camper if it is:
Mobil 1 15W-50
Back by popular demand, Mobil 1® 15W-50's high viscosity provides outstanding performance in high-revving, high-temperature conditions.
Mobil 1 15W-50
Mobil 1 15W-50 exceeds warranty requirements for gasoline engines where an API certified oil is specified. It meets:
* API SM/SL
* Requirements for Diesel Powered Vehicles where an API CF or API CD is recommended
* Provides extra anti-wear additive for older vehicles
Mobil 1 15W-50 is formulated with SuperSyn, an extra-high viscosity synthetic fluid, plus extra anti-wear additive to provide extra protection for severe service applications such as towing, hauling and racing. Mobil 1 15W-50 is recommended for high performance vehicles including turbocharged and supercharged engines where a thicker oil film is desired.
Mobil 1 15W-50 is also recommended for older valve train designs that may benefit from a higher level of anti-wear normally not required for newer generation vehicles. Mobil 1 15W-50 will also provide better anti-wear protection for higher valve spring tensions in certain racing engines.
The old 'red cap' used to be popular with motorcyclists.
Many have now switched to Rotella syn..
Don't know of any cycle riders who have tried the new 15/50.
