New label on Castrol edge at Walmart
Arkansas
Walked into Walmart yesterday and saw some new bottles of Castrol edge with a different label on the front. They claim for low and higher mileage engines. Is Castrol trying to Consolidate the Edge HM and Edge meaning all of their oils are now the Edge HM equivalent?
It seems like Valvoline has been pushing for this too.
Could be HM and regular are merging. Rotella Gas Truck does the same thing (calling it All-Mileage). They have to (or want to) meet SN, dexos1, and ACEA requirements, which include elastomer tests that have to hit a range, making extra seal sweller difficult to do and stay inside the limit.
New bottle, same oil inside.
The test results they boast do sound very good:
Interesting... they just redesigned the label like a year ago when they went from SN to SN Plus, although the non-SN-Plus viscosity grades still have the old label. Now they're changing it again? Same thing with Valvoline - they've done like three label redesigns in the last year or two.
Originally Posted by Duffyjr
Maybe they looked at what Pennzoil is doing and seen how ridiculous it is and decided to do the opposite. Less chin scratching for sure.
So true. Marketing is a battle for shelf space. Pennzoil has multiple labels on non-Platinum, non-Ultra, Full Synthetic varieties that Walmart & the autoparts stores may cry foul about because they only have so much shelf area.
Believe it or not, a big factor in this change might be due to what's mentioned in the thread title - Walmart. Available shelf space, just mentioned ^ above ^, is a huge thing with Walmart and vendors who want to sell at Walmart. With Castrol oil alone, I've noticed less and less Magnatec on the shelf at the nearby store, being replaced by Edge. It's routinely available for $22-23 too which is what Magnatec used to be.
EDGE is a great oil. Still surprised it's taking them so long to get Castrol EDGE Extended Performance D1/G2 approved. The only long drain oil to actually meet D1/G2 is Mobil 1 Annual Protection and Mobil 1 Extended Performance. AMSOIL Signature Series does not due SA levels exceeding what is required by the dexos spec.
Two excellent points.
EDIT: including paoester's as well.
Originally Posted by IronMaidenRules
So does it have a reduced amount of seal conditioners compared to a traditional HM? Aren't these undesirable for low mileage engines?
Fixed it for you. And the answer is no, it is not undesirable; MolaKule even previously weighed in on HM vs non-HM and said you may actually be better off with HM because of the increased antioxidants even on a brand new engine.
Castrol makes good oils in their Edge/Castrol EDGE Extended Performance line.
Considering that Shell was just named top lubricant seller in volume for the 13th year in a row, I'd take that to mean if they're doing the opposite they're going in the wrong direction.
Originally Posted by PimTac
Maybe High Mileage oils are becoming irrelevant?
Or possibly due to new technology High Mileage oils are becoming the better option? Valvoline indicates their High Mileage oil is superior in every way on the back of their bottles as compared to non High Mileage.
So does it have a reduced amount of seal conditioners compared to a traditional High Mileage? Aren't these undesirable for low mileage engines?
Fixed it for you. And the answer is no, it is not undesirable; MolaKule even previously weighed in on High Mileage vs non-High Mileage and said you may actually be better off with High Mileage because of the increased antioxidants even on a brand new engine.
Or is it possible they are using the same amount as the High Mileage? They could be using somewhere in the middle.
Originally Posted by wemay
I think it's genius. It puts the average consumer's mind at ease whether they can use it or not.
Agreed. For myself, I have pretty much resolved to using an High Mileage oil from day one. No reason not to. Even on a sportier vehicle. With the possibility of reducing the chances of oil burn, I see no negatives unless wear is that much worse. I believe most people would save more money not having to top off oil ever 1000 miles rather than your engine dying at 350k miles instead of 360k miles.
Maybe now they can sell gold bottle Castrol EDGE Extended Performance at the auto parts store I work at? Would be nice to have some competition to Mobil 1 Extended Performance on the shelf!
The 10X and the golden honey colored oil splashing through the silver spinning things is all I care about. That new bottle is sexy!
This is a trend Shell started and I predict that their lead will be one most end up following because it saves money in production costs and saves the customer the anxiety of having to decide between multiple, often seemingly redundant, choices.
Marketing department employees smoke funny weed and come up with this stuff.
And those are the employees most likely going to jiffy lube with groupons for their ten dollar oil changes
