- Joined
- Jan 29, 2004
- Messages
- 11
Click here for the Auto-RX instructions.
Looking at your basic application procedure with an engine over 100,000 miles.
Now, looking at "Second Application" under step 1, I think the first step should be to change your oil filter like as written in the "First Application" instructions. Cause you will have between 2,000 and 3,000 miles on the oil filter. Then it asks you to add 12 ounces of auto-rx. So you will have to loose some oil for the auto-rx so you don't have too much oil in there. So this would be accomplished by changing the oil filter. Plus it is asking you to drive 1,000 miles.
So what if you are done with the first application and then drive 3,000 miles, then follow the "Second Application" procedures for engines with over 100,000 miles and add 12 ounces of auto-rx and drive another 1,000 miles? That would mean you would put 4,000 miles on that same oil filter.
So, in conclusion, I think that first step in the second application should be to replace the oil filter as written in the first application procedures.
