Our house plan is at http://www.archwaypress.com/product.php/27.htm . We are going with the partial basement with the other half crawl space. If you have the time, I'm looking for any suggestions to improve or confirmation of what we have picked out so far.
We are using Boral brick, Concord with Colonial buff mortar, which seems to be a well-made brick. It will take ~ 46k.
We are ordering Silver Line (lifetime warranty) double hung vinyl windows with LoE/Argon.
We believe we will use Owens Corning Oakridge PRO 30 AR (algae resistant) shingles in Driftwood color. http://www.owenscorning.com/around/roofing/shingles/selectedstyle.asp?Shingle_Line=13
The housewrap was not as easy of a choice (for some strange reason). I think we are going to go with R-Wrap from Ludlow Products. It is $93/1350 ft2. http://www.covalencecoatedproducts.com/pdf/RWrap/RWrapTechSheetRW103M.pdf .
I had also thought about Tyvek at http://www2.dupont.com/Tyvek_Construction/en_US/assets/downloads/HomeWrapSpec.PDF , since it seems to be the most popular, but R-wrap seems to be better.
I had also looked at Typar ( http://www.typarhousewrap.com/housewrap-specs.html ) which is $85/900 ft2. PinkWrap from Owens Corning is $88/1350 ft2 ( http://www.owenscorning.com/around/insulation/products/pdfs/19731-D.pdf ), and GreenGuard Ultra Wrap from Pactiv ( http://www.pactiv.com/green-guard/ ). Any experience with house wrap?
We are planning on using R-21 fiberglass batts in the exterior walls with R-11 fiberglass batts for interior walls. The attic will be R-38, but I don't know if I want fiberglass batts or blown cellulose. I imagine the fiberglass batts will be more expensive than the blown cellulose. I know that I don't want blown fiberglass anywhere.
What do y'all think?
Thank you.
Thank you.
