I drove both the Odyssey and the Pilot today with the VCM. I could NOT detect the change over. Only when flooring it while in 3 cyl. mode did it instantly go into 6 and then the AT downshifted. I hate AT's, but there it is.
V-6s are shakers because they are a pair of threes cast into one. Absent use of an exotic, impractical-for-production crankshaft, there is no way to eliminate the longitudinal shaking that an inline three will generate, and a V-6, again, is simply two of these, side-by-side. I read an article about this engine, and recall that Honda deemed it necessary to use special engine mounts and active noise cancellation (ANC), via the stereo speakers, to make the NVH in 3-cyl mode acceptable. The ANC, I understand, is active even when you think the sound system is "off". It would be interesting to test drive one with the fuse for the sound system pulled.quote:
If Honda pulls this off it'a an amazing feat. A V6 is a shaker by design and needs a lot of help to run smooth. A three cylinder has got to be a shaker, too. Since the best reason to have a V6 is packaging you've got to be impressed with what Honda is doing.
