6300 hours is fine on the engine if maintained well. But a dual stage clutch may be worn out. That involves splitting the tractor which is not a small job. If the clutch is new or recent, I wouldn't worry about it.
It will pull a good sized mower and any other implement (plow, harrow, seeder, etc) that you need to plant and maintain the prairie. So its not necessarily a bad choice. Just need to know what your are getting into. Obviously a new tractor will be reliable and you can buy the implements with it.
