Originally Posted By: George Bynum
Originally Posted By: ZeeOSix
Originally Posted By: Artjr
Would you not have to ensure the larger filter still keep you pressure and flow within the required level for the engine your putting it on?
Oil pressure and flow are not really effected by the oil filter. Pressure and flow are determined by the flow resistance of the engine and the volumetric output of the oil pump, and also the viscosity of the oil.
Completely agree. By intent, the pump is positive displacement where flow is directly proportional to engine speed.
I suspect, but don't know, that all flow goes through the filter and the relief valve is after. Pressure is "created" by restriction and flow, limited by the relief valve. I __SUSPECT__ that oil pressure is stable for engine speeds above some arbitrary value, likely in the 1200 rpm range today (twice idle?).
The pump's relief valve is typically in the pump, so well before the oil filter. Oil pressure is only "stable" once the oil pump hits relief pressure. Otherwise, the oil pressure will increase with increased RPM until pressure relief happens.
A relief valve is not, in most cases, viscosity sensitive, so system pressure won't vary with viscosity; however flow distribution through the relief and through the engine would vary. That is, a SAE10 would have more oil through the lube passages than a SAE50, but both, courtesy of the relief valve, might operate at (I'M MAKING THIS NUMBER UP) 30 psi.
System pressure certainly does vary with viscosity at a constant engine RPM and oil temperature. The flow volume through the engine will be the same with 10 and 50 oil (due to the positive displacement oil pump) until the pressure relief valve starts to open. It's just that the 50 weight oil will make the oil pressure higher at each RPM point, and it will therefore cause the pump's relief valve to open at a lower engine RPM.
