New FRAM Racing Filters released at PRI
Scruffy City
Jay mentioned these in the Racing Section but the thread kind of went south.
They are now out but I'm not finding too much about them, in particular the media.
FRAM Racing Oil Filters
Anyone find any more detail?
We have been using those for years in industrial applications. 200hp driven Sundyne BFW pump. We have stocked them since 1992, so they have been around since then!
Per the article linked above, these look to be a redesign with improvements. I think the new version has metal end caps for instance.
The article says the media is high flow and 94% efficient at 20 microns. The filter looks to have a high bypass valve setting to prevent the filter from bypassing for engines using high volume oil pumps and thicker oil in racing conditions (ie, high RPM use).
Right, I am wondering if the metal end caps may be due to a wire backed media, though I suppose it would probably say that. The HP17 seems to be new, it seems to cross to the 7317
The article says the media is high flow and 94% efficient at 20 microns. The filter looks to have a high bypass valve setting to prevent the filter from bypassing for engines using high volume oil pumps and thicker oil in racing conditions (i.e., high RPM use).
Yep, and all but two have the bypass screen (not sure why those two do not).
The FRAM Racing filter line has been improved and five new parts numbers released. We now have street driving compatible, drag and road racing compatible filters in one package. The media is a 60/40 blend of synthetic glass fibers and cellulose. the flow rates range from 10gpm (HP17, Honda and Nissan) to 22gpm HP6 (Drag and NASCAR). The five new filters all have silicone adbv's and the legacy part numbers will migrate to silicone as inventory is sold. All the rest of the part numbers flow 15gpm and can be operated at 200psi constant pressure with a 500 psi burst strength. They are 94%@20 microns, have 6000 mile OCI capacity. they also ALL have a hi flow 22psi bypass with a 100 micron stainless steel screen over the bypass. Flanged metal end caps, 1/4 thick tapping plate. They are available for Honda and Nissan (HP17), GM LS early HP20, Late model LS and LSX is HP 18, Ford 4.6 and 5.4, FCA Hemi is HP16, HP19 fits Ford Coyote V8's and GM applications using the PH10060. No other oil filter company has racing filters for these applications.
Email me if you want more info. I am sending some to a BITOG member next week for dissection so watch for it.
Thanks for the info Jay.
I don't know my filters that well, but it looks like the Fram xx8a / MC FL-1A size will not be included?
The bright orange color would look good on a bright orange classic car.
Whatcha need a racing filter the size of a 8a for? You plan on racing the 4.slow? xD
Yes thanks Jay.
Believe FL-1A = HP1 which is part of the existing line I believe.
Originally Posted By: Motorking
The flow rates range from 10gpm (HP17, Honda and Nissan) to 22gpm HP6 (Drag and NASCAR). The five new filters all have silicone adbv's and the legacy part numbers will migrate to silicone as inventory is sold. All the rest of the part numbers flow 15gpm and can be operated at 200psi constant pressure with a 500 psi burst strength.
Jay ... was wondering if you could elaborate some on the flow GPM rating specs. I see this from other filter manufacturers too, and it's kind of a nebulous spec to people without knowing what it really means.
As you know, the delta-p across the filter will change with flow rate and with oil viscosity - they are all interrelated to each other. Is that max GPM flow rating taken at some standard conditions (oil viscosity, delta-p, etc)? Is it the max flow it will take with some viscosity of oil before the bypass valve starts to open? I've never heard from anyone what the spec really means.
If I had to hazard a guess it'd be the most common oil (10W-30 conventional) at a common operating temp (200*F).
Sure, 20W-50 or straight 50 will flow far less when cold... but at operating temps, if straight 50 flows 3% less (or even 4% less flow GPM) it's probably doesn't change the spec enough to warrant issuing a statement about it.
To you or me, it doesn't really matter.
Think about this: if your sump holds 4 quarts and your engine moves 20 GPM, that means the sump is being completely drained and refilled (1 gallon) every 3 seconds! It's just not possible.
Even dry sump NASCAR engines don't pump 20 gallons per minute through their bearings. Not even CLOSE......
I think an average racing V8 might possibly move 5 GPM at full boogie on a good day. That's draining and refilling the sump every 12 seconds, which I think might still be unlikely, or at least not very common.
when Fram refers to street performance, would this be "the" oil filter I`m looking for in a boosted application that see`s 100% street driving?
Jay told me to order the FRAM Racing oil filter HP20 for my application, which I did through Summit and the invoice is not mentioning "Racing" anywhere.
Checking FRAM website the HP20 reference is not labeled "Racing".
Does that mean there is a difference between the "Racing Series" and the "High Performance series"?
NEVERMIND, after putting my glasses on "Racing" it is written...
Looks like I have a an alternative to the Moroso racing filter...
I look forward to cutting one open and checking it out.
UD
Yeah, but the viscosity is only part of the 3 variable equation. If the filter is flowing 15 GPM with 10w30 oil at 200 deg F, then what's the delta-p across the filter? When a max GPM flow spec is given it needs to be qualified to under what conditions it's flowing that max GPM. I have never found any solid technical information saying exactly what those conditions are.
There are a couple of threads in this forum talking about the oil pump specs on Subaru 4-cylinder turbos, and the factory shop manual showing the pumps in those engines putting out something like 12~14 GPM. I'm sure that there are many factory stock high performance V8s on the road that put out way more than 5 GPM. My Z06 was rated at around 10~12 GPM max output. Something like a 4 banger Honda Civic will probably be putting out 5 or 6 GPM max.
It's been a few years since I have built racing engines, But I recall those numbers were always "bench test" numbers... and at "zero restriction" at that. I seem to remember all published Melling pump info was like that.
Meaning, stick the pump in a 5 gallon bucket of oil and spin it with a drill while it pumps through a 1/2" hose (at 0 psi, really) into another 5 gallon bucket. They'll move Many ,many GPM in this scenario, yes.
However, your "typical" engine, with typical tight bearing clearances (forget drag engines for a moment) - will NOT flow that much, no matter what the pump specs are. Like I said - - you physically can NOT drain and fill a 4-5 quart oil pan every 3-5 (20 & 12 GPM, respectively) seconds.
Oil simply will not flow by gravity into the pan fast enough to replenish the supply. I also know for a fact your crank doesn't move a gallon of oil every 3-5 seconds - the windage losses would be insurmountable. No one builds a windage tray or dry sump system (single stage) capable of evacuating an honest gallon of oil every 3 seconds. It just isn't realistic to expect an oil filter must flow 20 GPM... because your engine simply doesn't.
Drag race engines are a very different animal - but if we were still building $50,000 I'd not care what someone on an internet forum says as long as it functions, which is exactly what we did 25 years ago.
Since you appear to drive a corvette, here is the published specs for the LS series Chevy pumps: 6.5 GPM.
That sounds EXTREMELY realistic to me.
No need to get worried about GPM ratings on oil filters.
http://www.improvedracing.com/oil-pumps/...pump-p-486.html
When asking Jay about flow rates in the past (specific to Subaru) it was quoted as flow rate @ temperature and viscosity (30W and 180F). For example, the GPM for Fram Ultra spec'd for Subaru Forester is 10gpm, <4psi delta, 30W, 180F. From my understanding the high flow rate of the Subaru engine is only at high RPM. For example, Jay told me that the Subaru boxer engine doesn't actually flow more than 10gpm at up to 6000rpm and that bypass events are limited to only very high rpm and extremely cold starts.
Keep in mind that when the pump is on an engine it can supply oil at 100+ PSI (whatever the pump releif is set to - some Subarus engines are around 140 PSI relief) in order to force it's positive displacement volume through the engine's oiling system. Also keep in mind that the total oil flow going through the engine isn't all flow to the main and rod bearings. Also, main and rod bearing oil flow volume is a function of both RPM and oil supply pressure, so that's why they can flow way more than you would think just due to pressure on a tight clearance.
All the oil that leaves the oil pump goes through the full flow oil filter. So in other words, the oil filter is seeing all the flow that supplies the engine's oiling system if the pump is not in pressure relief. Most high performance engines have larger oil sumps (6 to 8 quarts) to help keep the sump level at a reasonable level when the engine is at high RPM and the pump is putting out max flow.
If the oil pump is not in pressure relief, then all the volume leaving the pump is going through the filter and engine. Engines certainly can flow 10~12 GPM with hot thin oil. My Z06 was not in pressure relief at near redline, so the filter & engine was seeing all the flow. It wasn't a few GPM, but more like 7 GPM if you believe the Melling graph.
And bench testing oil pumps with no back pressure is very misleading data, as it won't show what the pump's internal slippage is. I suspect those Melling graphs are with some significant back pressure, and probably flow that was recorded on an actual LS engine. That why they knee over in the high RPM region.
It certain can when it's hot and thin as water. And if the pump has a high pressure relief setting, it ensures that all the oil leaving the pump goes through the filter and engine. I like this old 1937 demo: https://youtu.be/vz2p1SvuYjY?t=9m45s
