I picked up a filter to use in my neighbor's car today, Fram appears to be making some the cartridges in Argentina now?
Metal crimp seam, pleat spacing looks good.
I paid $4.80+tax, Meijer has Fram filters on sale for 20% off, they're normally about $6 everywhere, Walmart has made all the Supertech Cartridges MP instead of ST now, so they're the same price as Fram, $6 is about the cheapest you can get a filter for these if they're not on sale and you're not buying in bulk on RA
They are more like a Beige color. OP Hopefully they will look this great on a regular basis.white plastic end caps
I like the metal seam. Nice photos. Thank YouI picked up a filter to use in my neighbor's car today, Fram appears to be making some the cartridges in Argentina now?
View attachment 159533View attachment 159534
Yes, That would be for the lid/capAnyone know what the little oring is for?
If there is a drain on the cartridge filter housing, it might be for that. The large O-ring is obviously for the main cap.Anyone know what the little oring is for?
Is there a drain? This is a top mounted cartridge housing.If there is a drain on the cartridge filter housing, it might be for that. The large O-ring is obviously for the main cap.
Apparently some models that use this filter have a bottom mounted housing that have a drain in the cap, so the small oring is not needed in my application.If there is a drain on the cartridge filter housing, it might be for that. The large O-ring is obviously for the main cap.
Could be on another vehicle that specific filter is also specified for.Is there a drain? This is a top mounted cartridge housing.
Not that I’ve ever saw on any encore or track or CruzeIs there a drain? This is a top mounted cartridge housing.
The same filter is used on the second generation of Diesel Cruze that has the filter on the bottom side of the engine.Not that I’ve ever saw on any encore or track or Cruze
Ok, does that cap have a drain hole?The same filter is used on the second generation of Diesel Cruze that has the filter on the bottom side of the engine.
Yes, I think it's the only application for the filter that uses it, and they were introduced in like 2017, so only recently have aftermarket filters started including the little oring, it's mostly a waste to include it since probably 99.9%+ of all people buying these filters don't own a 1.6L diesel car.Ok, does that cap have a drain hole?
