Originally Posted By: Finklejag
The viscosity index went from 151 to 157.
I thought I'd post this to go along with your information in case somebody wants to know what Viscosity
Index is. I was reading a little bit of this last night at Amsoil's site. They explain it pretty good:
Quote:
The less change a motor oil has from high to low temperatures gives it a high Viscosity Index. Synthetic motor oils that are made from Group IV (4) PAO base stocks have Viscosity Indexes of more than 150 because they are manufactured to be a lubricant and don't have the paraffin that causes the thickening as they cool. But petroleum based motor oils (Group I (1) & II (2)) usually have Viscosity Indexes of less than 140 because they tend to thicken more at the colder temperature due to the paraffin despite the addition of Viscosity Improving additives. The higher the Viscosity Index number the less thinning and thickening the motor oil has. In other words, high number good, low number bad. Low numbers thicken more as they cool and thin more hot. You see these Viscosity Index ratings posted on data sheets of motor oils provided by the manufacturer.
Originally Posted By: ted s
SO in english what does this mean?
They're just telling you that petroleum based oil thins out with an increase in heat; and to counteract the thinning out, it needs viscosity index improvers. PAO based oil doesn't thin out with heat as easily as petroleum based oils; therefore, it doesn't need the viscosity index improvers that petroleum based oil needs.
