That is not true. There all over Mexico still95 Sentras rusted out here 20 years ago.![]()
You missed the satire.He said "here" and not "everywhere" ... he's in Central NY.
I am a big Nissan fan (at their peak). I would be tepid to buy a new one due mostly to their current financial situation.
I don't know how it works on this vehicle, but some Ford escapes have the same belly pain issue, but there is an aftermarket upgraded (plastic) pan available that has a removable spot for oil changes that makes it much easier.Do you plan on diy oil and filter change? If so, entire splash shield/belly pan must be removed to access both oil drain plug and filter. That involves removing multiple plastic push pin clips 'at least' mid-teens+ in number. And several bolts. If one had a lift, tolerable perhaps. Ramps or jack stands, very diy unfriendly in my observation. Rogue the same deal. I've read comments saying not 'that bad', I don't agree. If that doesn't bother you and you're ok with the CVT, I guess it's an option.
I agree. Cut a hole, make your own cover.I don't know how it works on this vehicle, but some Ford escapes have the same belly pain issue, but there is an aftermarket upgraded (plastic) pan available that has a removable spot for oil changes that makes it much easier.
Watch the youtube video in post entry #18 of this thread, shows exactly how it works. As for the suggestion(s) cutting an opening or opening in the shield, air getting up in those openings causing flapping of the shield at speed needs to consider. I've even read some trying zip ties to hold cutout openings in place to reuse.I don't know how it works on this vehicle,......
I was implying that if there was an aftermarket solution available for one vehicle, it sems likely to be available for others. I would never cut a hole one myself. I think the price for the aftermarket solution was under $100Watch the youtube video in post entry #18 of this thread, shows exactly how it works. As for the suggestion(s) cutting an opening or opening in the shield, air getting up in those openings causing flapping of the shield at speed needs to consider. I've even read some trying zip ties to hold cutout openings in place to reuse.Ideally, like your Escape example, some aftermarket maker would come out with a more user-friendly replacement. But, they would need to bring it in for a reasonable price.
Didn't mean to imply the you specifically would cut a hole, mostly responding to reading other comments suggesting that as an option. As for an "aftermarket solution" to the Nissan shield, to this point I've seen none. And the remove it all shield design been around now for at least 4 years. Seen mention of it as a potential solution in youtube comments, but not one pointing to a product. So 'afaik', unlike the linked Escape, nothing comparable for the Senta or Rogue for that matter.I was implying that if there was an aftermarket solution available for one vehicle, it sems likely to be available for others. I would never cut a hole one myself. I think the price for the aftermarket solution was under $100
Like this one: https://www.amazon.com/Fischer-Compatible-2013-2019-2015-2019-Lincoln/dp/B076FV8G3M/ref=sr_1_1
That is not true. There all over Mexico still![]()
2017. Was called the Tsuru there. Was the top selling car in Mexico for ages.I think the B13 Sentra was made until like 2015 or so in Mexico. I'd hope they can last 10 years in a salt free climate![]()
Statistically speaking, Corolla would last at least 1 year and 21k miles longer than a similar priced Sentra, so I wouldn't be worried about buying a year and 21k older for the same price.The Corolla would be a 2023 with about 27K miles, for $19.7K
Corolla also has a CVT. If you like Toyota, you may as well get a Camry that has a normal automatic transmission.I'd look for a Corolla. I was obligated to say that. I have owned a 1988 and 1991 Sentra, both really good cars, not sure if the new ones are going to be as reliable.
