I have read numerous threads on here regarding what sounds like a similar problem, and have followed the advice I found, to no avail. I have two cars that needed front pads replaced at the same time; one is a 2003 Camry w/150k, the other a 2016 Outback w/62k. I used Carquest Gold on the Camry, Carquest Standard on the Outback, both ceramic. Before replacing I checked the rotors, and they were smooth on both cars. I greased the mounting notches and sliding pins on both. I did the repeated accelerate/stop break in. They worked great with smooth, quiet, effective stopping when up to speed. However, when inching forward at a redlight or backing out of the garage, applying the brakes produced a significant noise. Not a high pitched "squeal", but more of a loud "creak" like a big, old door opening. So today, I took the front wheels off of the Toyota, removed the calipers and rotors, regreased the notches for the pads, and cleaned everything thoroughly with Brakleen. Reassembled and torqued everything to spec. Result: Better, but still "grabby" and loud creak when applying brakes at very low speed. Once up to speed, braking is excellent. Any thoughts or suggestions are appreciated; thanks in advance.
