Originally Posted By: 440Magnum
Originally Posted By: Corvette Owner
I have a 2006 Nissan Murano with a CVT transmission. These transmissions are way easier on fluid than normal automatics, as they do not have as many clutch packs and don't use them for shifting into gears.
Define "easy."
They don't heat fluids as much- that's easy. They don't shed clutch material (wear byproduct) at anything close to the rate and volume as conventional automatics- that's easy.
But I'd be willing to bet that the action of grinding the fluid between that steel belt and the steel sheaves will shear some VI improvers and other polymers like he**, so in that regard they may be more demanding.
Exactly, I was wondering if there's a lot of shearing due to the belt. I drove the GF's '07 Murano quite a bit and the convertor clutch locks up very early on and stays locked. I would think heat would almost be a non-issue unless the belt to pulley interaction could make heat even though as I understand it there's no slip.
The one thing I don't like is it's very, very slow to respond when you need it most. If I have to pull out into traffic in a very heavily traveled road which requires full throttle, rpms go to 3,000 and very slowly ramp up to near redline. I'm talking about 3+ seconds to get some real rpms.
The other complain is the programming. If I'm doing a minor hill climb which was frequent in the oil fields and 1/4-3/8 throttle, the convertor would lock early on as usual but it would try and bring rpms down to 1,100, causing pinging even on premium fuel. Pulling it into the "sport" setting was too far the other way, a constant 4K-4.5Krpm.
I guess I'm going to be one of the first on here to try the Redline fluid in it. It has about 32,000 miles so it's time and I'll post the results in a month or so.
Has anyone seen a used oil analysis on one of these things? If not I may do one just to see what it's all about.
