Originally Posted By: jhellwig
7018 isn't needed for this and only recently have the came up with AC version of 7018 plus they need to be kept in an oven. If you clean the rust off the area to be welded and you are relatively flat go with 6013. I think 6011 is supposed to be used with DC but I might be thinking about 6010.
6011 stick rods can be used on DC or AC. If on AC then you would need to turn the amps down by about 10% from DC. Either way, with 6011 rods you get very good penetration.
Also 6010 rods need to be run on DC.
