Need some advice on an Outboard motor problem.
Warner Robins, GA
Last summer I was given (I am learning quickly there is no such thing as a free boat) a 16ft john boat with a 1975 Johnson 25hp electric start motor. It had been sitting for about ten years, but ran fine when parked. So I rebuilt the carb and rewired the motor. It fired right up and was running fine (motor in a bucket of water in the yard) Problem was after it was warmed up it would not start again. It has spark, and the plugs are wet, but sometimes it will just not fire up after its warm, even with starting fluid. Any ideas? On another note today I had it running, shut it off, then it wouldn't restart and I went to pull the plugs and one of them stripped the threads. I ordered the helicoil kit for it and am praying that will work. Anyone used these on a spark plug with success? Thanks in advance for your responses.
The helicoil kits work very well so long as you install them properly. Ask someone with a Ford 5.4L "Triton" engine whether they work! They might as well live by them...
You're either running out of fuel or spark, or too much fuel.
Pump the fuel bulb much prior to hot restarts. Also, try restarting at different throttle positions.
Replace fuel hoses and make sure there are no kinks.
Make sure that your oil/fuel ratio is correct.
Helicoils work if done correctly. Learn to use a torque wrench on spark plugs.
If it has the older mag ignition system, you need to get th magnet "recharged" Recharge may not be the correct term but, an older Johnson/Evenrude dealer can zap the magnet to increase the magnetism and you will get a much stronger part. A good spark when turning the motor over by had with the plugs out should produce a spark about 1/2 inch long with some orange/yellow in it. This from experience with the old Green and white series Johnson's.
FWIW, I once diagnosed a similar condition (no start when warm) to a sheared flywheel key. It put the timing off just enough to allow a cold start but not a warm restart.
Check Ebay, you can probably pick up another head cheap for a motor that old. I never had luck with the helicoils in a head application, especially on a two stroke.
I think your runnin rich in low speed.
Try set the lowspeed jet.
Gently turn it in until you have highest idle and
then 1/8 turn out. Reset idle speed and repeat.
Make sure the carb doesent flood.
