Need recommendation - 30 weight non-detergent motor oil
R&Os / Turbine oils are often used in lightly loaded gear box applications. Which is probably where the recommendation came from.
a non-detergent 30w and an R&O 100 are the same. So for example, the Citgo / Mystik ND 30w and the Citgo Pacemaker 100 are extremely similar products.
Good point! Mobil DTE Heavy is ISO 100. There are lots of options in R&O/Turbine oils in that weight. Most sold in 5-gallon pails. I use DTE Light in my lathe. Some people confuse this type of oil with hydraulic oil, which is different, but typically works okay interchangeably. It's not cheap, commonly $200/5-gallons.
https://petroleumservicecompany.com/iso-vg-100-sae-30-non-detergent-oil/
What you're looking for is what would have been spec'd as "API SB" motor oil until they stopped doing that after lawsuits a few years ago, Valvoline/Napa Non-Detergent fits the bill you're looking for also AW100 Hydraulic fluid (which the Napa/Valvoline claims it can also be used as, or a good 30 grade/ISO air compressor oil since it sounds like you want anti-wear/anti-oxidant just not a modern PCMO package.
