Would be good to get a digital voltmeter and check:
Battery resting (should be ~12.7v as said above)
System voltage at idle, no accessories, should be low 14's.
System voltage at idle, everything on... defrost, lights, heated seats... should be between ~11.5 (batt discharging) to low 14's. But when you raise the engine to 2500 RPM you should go up to the low 14's! If the battery is a real turkey it won't be able to supply the deficit and could dip below 11.5 volts.
The alternator is rated to supply everything AT SPEED, there will be normal dips at idle. If the alt is going bad you won't get the 14v you need and be more often discharging the battery.
