I have been trying to research factory replacement blocks for the 3.7L TL engine.
Mine is being replaced by Acura for excessive oil use. What has been done by Acura to insure that the replacement block will not suffer the same problem?
As far a I can see, one of three problems exist (certainly could be more)
1. Cylinder walls were improperly prepared.
2. Rings were improperly installed with gaps lining up
3. Rings and cylinder walls were incompatible resulting in excessive wear.
Does anyone have information on what modifications, if any, have been done?
Thanks
Thanks
