I've got a question about the viability of using this oil under questionable circumstances. I just had a UOA done & it came back with high viscosity (18.7 cSt) & low TBN (3.0). The lab had this to say about it:
I changed both the oil & filter in mid-July when I sent in the last sample. I wasn't aware of the engine temp problem at that time. We then went from Denver to St. Louis & back, & after one month we now have about 3,000 miles on this new oil. This weekend we're leaving from Denver to go to Phoenix for a week, so we'll easily put another 2,000 miles on the car by the time we return. I'm sure this is one of the absolute best oils available & I'd like to continue using this batch for a full 10k mile interval if it's safe to do so. Obviously, it's not worth sacrificing the engine bearings or turbo just to extend the OCI, but I'd also hate to dump out $25 of good PAO oil & filter if I don't have to.
FWIW, the UOA came back with excellent wear numbers. Even with the high oxidation/thickening & low TBN, iron & lead were both about 1/4 of what they were using M1 0W-40 for the same OCI. Based on the overall results you've seen with this oil, what would you guys recommend I do with the stuff that's still in the engine?
Based on the reasons they gave for thickening (coolant contamination or gross oxidation) & a little research into the failure/repair history of this Saab model, I realized the probable cause was overheating due a faulty thermostat &/or Engine Coolant Temperature Sensor. The local Saab garage told me they recommend replacing both components "every couple of years, to avoid problems" & ours are now 6+yrs/63k miles old. I've got the new parts & will replace them in the next day or two.quote:
The only two things that thicken viscosity are antifreeze (which you did not have) and extended oil drain. An extended oil drain would cause high oxidation which thickens the oil. ... Oxidation is caused by overheating, a coolant problem (bad coolant), or extended oil drain. On the last sample you had 4820 miles on the oil, this sample had 8498 almost double. Low TBN indicates that the oil condition is poor - the oil additives are being used up and the oil is losing its ability to neutralize acids. Again, I would check for overheating and/or check you coolant to see if there is a problem.
