The LiFePO4 batteries that are configured for starting are epic good. I don't know how it would compare in your situation, he uses it to start a 540 cubic inch Lycoming aircraft engine. It will crank and crank seemingly forever. Those engines when hot can be difficult on the best days. They tend to draw quite a bit more than car engines and are tough on batteries.
The BMS on many of these LiFePO4 batteries are not designed for high amp draw. But on the ones that are, they work exceptionally well. Also, the BMS will reset in a few seconds on some models. Others the BMS 'latches" and it may take a pair of jumper cables to bring it back.
A starter for a 460 ford is the same size motor as my 12,000lb winch, so that tells me a little something.
So how do you tell what the BMS is designed for? Is it just a gamble?
