Vehicle is 1k shy of hitting 100,000 miles.
Exterior and Interior are in showroom condition.
Money is not my biggest factor since it is a long-term keeper.
Problem:
On braking the car has begun to dive a bit, and on rear bumbs I am getting a crashing-hammer sound from the right rear.
I suspect the assembly line Decarbon Struts and Shocks are at there end.
What should I replace with? Primary concern, similar performace to OEM and long life.
Here are the brands I dug up, please post your recomendations and experiance on them.
I am leaning towards Decarbon, since some say Bilstein is bone jarring? Sensatracks are quite cheap$$$ wise. Although, they are cheap they eature a liftime warranty and rebate. My fear is skimming cost for quality.Tokico looks interesting on paper. Tokico, Monroe, Bilstein all advertise themselves as OEM suppliers.
I will do front struts and rear shocks all same time, maybe ball joints to depending on board advice.
Bilstein
DeCarbon.
AC Delco
Monroe SensaTrack
KYB
Tokico
Second, should the front strut mounting plates be replaced same time?
Third, is it true when replacing front struts, the ball joints are easy to replace same time?
If so is it the upper or lower ball joints or both that are easy to do then?
Problem:
Bilstein
DeCarbon.
AC Delco
Monroe SensaTrack
KYB
Tokico
