I saw this on a Toyota board and I'm wondering what you folks think of it:
>At 700 miles I changed the oil to Castrol GTX
>5w30 conventional oil with a Mobil 1 filter.
>At 3,000 miles I will change the oil again using
>Castrol but then switch to Toyota brand filter
>for the remaining life of the car.
>I’m driving very easily while the Mobil 1 filter
>is on the car. The Mobil filter filters very
>well, but it does not flow as well because of its
>filtering efficiency. I have seen some oil
>analysis reports which show wear numbers can
>actually be reduced by using filters that flow
>more while not necessarily filtering as well.
>The reason is because during high RPM or heavy
>loads sometimes oil filters go into by pass mode
>to ensure the engine has all the oil it needs.
>This happens because filters are a restriction
>and if the engine is demanding more oil than the
>filter can provide (maintaining the correct oil
>pressure) the filter is bypassed to ensure proper
>pressure. While this is good, it’s also bad
>because while in bypass mode the oil is not being
>filtered. I chose to use the Mobil 1 filter while
>the engine is breaking in because it filters
>better and I am driving it VERY nice to avoid any
>bypass situations.
My question is, is the poster's concern warranted? What if he switched to something like a K&N filter to give better flow and nearly-as-good filtering?
>bypass situations.
