I get so much use out of the Milwaukee cordless inflator. I am not buying Milwaukee products anymore.
I have both the M12 and M18 inflators. They are awesome. The M18 is obviously better, but the M12 is the perfect size to toss in the trunk on a road trip.The Milwaukee M18 is king for battery inflators. I've used it quite a bit and only hit the duty cycle a few times.
I also have the Dewalt inflator, its slow but gets the job done.
I had a slime that lasted at least 13 years before it finally died it was great so I decided to buy another slime.Just bought this at Walmart for the wife's Subaru and her mountain bike. It is the medium duty unit of the line. It's pretty slick as you set the target pressure and it shuts off when it reaches it. When I inflated her car tires for the colder days ahead, I set it at 35psi and after it shut off, I verified with my pencil gauge, and it read 35psi on the nose.
BTW this replaces an older model Slime light duty unit that lasted 17 years - and the motor was good but the hose dry rotted and split.
Yeah, I have a 2 gallon compressor light enough for that and just leave 12V compressors in the vehicles …Plot twist, what if you got an air tank with hose and chuck you could take down to the trailer? It'd be reliable as all get-out.
Hmm. That is not good. I hope mine lasts longer than that! I did see the air intake grille on the bottom can pick up road debris. So I am setting it on cardboard. Question - can these be oiled?I had a slime that lasted at least 13 years before it finally died it was great so I decided to buy another slime.
Well the one I bought is the same exact one you just showed and it lasted a handful of air ups before the piston inside came apart, was able to fix it and then a few more air ups the hose broke.
They don't make them like they used to.
If you have any of the major battery power tools (Dewalt, Milwaukee, Ridged, Ryobi) All make good tire inflatorsWhat current batteries do you have?
agree the Dewalt is way better than I thought it would be. It's on the big side, so it might not be practical for everyday carry in smaller cars.
I'm a fan of the Viair 88p as it clamps to battery, fills stuff quick, not worried about charge running out. Battery clamps means not relying on small wires/power outlet limits. It has it's own 20A fuse.
You get so much use out of the Milwaukee inflator (I assume that means you like it?), but you’re not buying Milwaukee products anymore? Can you elaborate?I get so much use out of the Milwaukee cordless inflator. I am not buying Milwaukee products anymore.
Milwaulee battery tools are now made in ROC.You get so much use out of the Milwaukee inflator (I assume that means you like it?), but you’re not buying Milwaukee products anymore? Can you elaborate?
