Need a filter for new Tahoe.
Quote:
We bought a 2007 Chevy Tahoe last week and the AC Delco filter is a PF48. I can't find an PF 48 anywhere. I've tried some cross-referencing but can't seem to locate another quality filter. Fram and STP are pretty easy to find but not what I want to use.
I'm not real keen on buying one from the dealer either, unless its my only choice.
Any recommendations on a replacement for a PF 48?
What are the Fram and STP numbers for the PF 48?
Quote:
FL820s
Let's take undummy's number for a spin
Part Number: 51372
UPC Number: 765809513723
Principal Application: Ford/Lincoln/Mercury (91-06), Mazda (00-06), Cadillac STS-V, XLR-V (06)
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.167
Outer Diameter Top: 3.660
Outer Diameter Bottom: Closed
Thread Size: 22X1.5 MM
By-Pass Valve Setting-PSI: 12-15
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=12/25
Burst Pressure-PSI: 275
Max Flow Rate: 11-13 GPM
Nominal Micro Rating: 19
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.834 2.462 0.200
Let's compare it to the 57060
Part Number: 57060
Principal Application: Various GM Vehicles (07)
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.430
Outer Diameter Top: 2.970
By-Pass Valve Setting-PSI: 8
Max Flow Rate: 10-12 GPM
Gasket Diameters
Attached 1 2.750 2.410 0.270
I'd say that it works ..if you have a little wiggle room. Naturally you'll have all kinds of anxiety over it not matching OEM size ..but ..
