True. The whole thread is biased towards the survivors, making it look less dangerous than it really is.quote:
Originally posted by den_s:
Too bad many folks who died during their oil change can't tell us their story...
That is one of the funniest things I've ever read.quote:
Originally posted by Evil Ron:
Near death experience? Well, when I was fifteen I told my dad to #@&*! off.
From what I heard, very painful and kinda slow since it doesn’t smash body organs completely.., all depends on chest dimensions and clearance between oil pan and ground. I always change my oil without jacks as well. I’m w/h proportional so don’t have any problems. Even under small sedan like my Mitsubishi Mirage there always enough space to open/close fumoto drain plug and change filter. There no space left and feels very uncomfortable but it saves a lot of time and most important my life.quote:
Originally posted by KieferS:
i imagine you'd die pretty fast? after reading this thread- idid an oil change on my car yesterday- with out jacks.
Give me a break dude, life is short,(and even shorter for others) take a laxitive or something.quote:
Same here. But the pin-through-shaft type has it's own problem: it may weaken the shaft. I saw Walmart was selling stands with a second ratchet pin in addition to the claw, those may be better. What I use is a pair of 6 ton jack stands, they are high enough so that ratchet is not engaged, and I put an additional pair of 2 ton stands, plust two floor jack under the car.quote:
I don't trust jack stands either. Even the heavy duty jack stands with the ratchet bother me. I want a positive pin throught the shaft, not a ratchet.
Hmmm, maybe get the heaviest duty ratched jack stands, find the level that you will be using them at all the time and then weld the ratched in place. That ought to be totally secure.quote:
