Napa 15w50 Synthetic
NH
I need to change the oil in my Hydro Gear hydrostatic trans. The original oil is 20w50. Napa has a sale on there 15w50 synthetic for 3.29 per qt. Is this a good oil for my application or should I use a Mobil One 15w50?
20w50 in a hydrostatic drive? Are you sure? Sounds a bit strange. I'm no hydrostatic drive expert, but the ones I've seen used some type or other hydraulic fluid.
I personally would use 20W-50 Mobil-1 V-twin. It's a tough oil that works well with a wet clutch system and would be perfect for your application.
I have a Tuff Torque and use the Amsoil 30wt Hydrostatic Oil.
I wen from the Manufacturer's (Simplicity brand Oil (10w-30)to Amsoil's 5W-30 Hydrostatic oil...quiter...crisper...smoother...cooler running.
Great stuff.
